Why are MB sparks so expensive?
Discussion in 'Engine' started by uumode, Sep 7, 2006.
  1. uumode
    uumode Hardcore MB Enthusiast
    1,504
    Sep 1, 2003
    Car:
    W205 C200 AMG Line Premium Plus
    Dealer price for changing sparks on E240 is a shade over £200
    (and that's with 10% off parts and 40% off labour)
    I think there are 2 sparks per cylinder so = 12 spark, but even so... :crazy:
  2. BenzComander
    BenzComander Hardcore MB Enthusiast
    1,044
    Sep 17, 2004
    Bucks
    Car:
    E320 Avantgarde Estate
    Chris Grey just changed mine (E320) for about 6.50 each!
    HTH
  3. OP
    OP
    uumode
    1,504
    Sep 1, 2003
    Car:
    That's including labour? - I did a quick Google on Chris Grey and he came up as a guitarist - not the same one I gather :)
  4. Birdman
    Birdman Hardcore MB Enthusiast
    908
    Dec 16, 2004
    Oxford, Oxfordshire
    Car:
    E55 & Phaeton
    I got mine changed for £80 labour + parts IIRC which was 2 hours at the East Coast indy rate.
  5. OP
    OP
    uumode
    1,504
    Sep 1, 2003
    Car:
    Geez... 2 hours to change the plugs? No wonder main dealer is wanting £200 if you factor 2 hours of main dealer labour... now I understand :) I thought it was a 'quick' 15 min job :crazy:
    Sounds like the plugs are mounted in some complex manner neccessitating awkward extraction and replacement?
  6. stats007
    stats007 MB Club Veteran
    5,880
    Aug 10, 2003
    Hampshire
    Car:
    575M
    Some layouts are more complex than others but I've done all 16 on an SL500 twice now and it's an easy job to attempt yourself - an hours work so no idea why MB charge two.
    You can source the plugs yourself - I upgraded to Iridium plugs - all 16 were £95 including delivery from www.apd.co.uk. Not sure if they're still trading. Plugs I bought were NGK BKR5EIX.
  7. C43AMG
    C43AMG MB Club Veteran
    6,686
    Apr 15, 2005
    Weybridge. U.K
    Car:
    500L ( W221 ), 2014 AMG CL 5.5 Biturbo ( W216 ), 2010 Brabus Smart ( Exclusive ) )
    Not on the C43 :(
  8. stats007
    5,880
    Aug 10, 2003
    Hampshire
    Car:
    575M
    Well if you will buy these AMG cars with big engines crammed into small places ;).
    Shouldn't be too hard though Pete? A lot easier with the vanity cover and coil packs removed obviously.
  9. Birdman
    908
    Dec 16, 2004
    Oxford, Oxfordshire
    Car:
    E55 & Phaeton
    You need to be careful not to break the tip connector when extracting leads, I'm told. And the plugs nearest the firewall are hardest to remove, so they say.
    Then there's the risk of cross-threading. I gather that's definitely an issue.
    Not at £40/hr though!:)
  10. Ian B Walker
    Ian B Walker MB Club Veteran
    7,672
    Jun 7, 2003
    Freckleton
    Car:
    300-24, saloon and coupe, E300 24 valve diesel estate
    Believe what you hear. Not easy I can asure you but someone is going to come along and say its dead easy :D :devil:
Share This Page
