Bellow
Hardcore MB Enthusiast
Closed loop will keep the optimal AFR ratio as the revs are dropping through the table. Just shutting off one or the other will result in massive engine braking which you may want on a race car, but not on a road car.
Cutting fuel only (leaving butterfly open) shouldn't increase engine braking - notice the lack of on diesels but shutting the throttle certainly does. It wouldn't be worse though than pre FBW days but worth avoiding I'd have thought for that reason and others (oil consumption?).
I wonder then the over-run strategy on Phil's FBW K1600. To this point (in time) it has been standard practice for bikes to have the so called 'slipper' clutch release on over-run - frequently under vacuum operation/activation. A FBW set up could obviate the need for that - providing it doesn't mess up the cat.
