Will 19" wheels from an E63 fit a C63 C205?
Mythical
South Yorkshire
C43 AMG (C205)
Hi all,
I'm currently after a spare set of wheels to stick some winter tyres on, I've seen a set of 19" which belong to an E63 W213 -
They're A2134012700/A2134012600, sizes are ET55 10J rear and ET25 9J front. On the C205 fitting is ET57 rear 10.5J and ET25 9J front, am I right in thinking the E63 wheels will fit? Never been great with wheel fitments so just want to make sure I'm not missing anything :)
The Sizes and ET you are quoting for a W205 C63 are for a Coupe only. A saloon has different offsets and ET's which are Front ET38, 8.5j and rears ET56, 9.5j
If you are fitting the W213 E63 wheels on a W205 C63 saloon, the fronts will be 9j instead of the recommended 8.5j and the wheel will poke out an extra 13mm (38 - 25)
Try this chart with both sets of wheels and tyres and see if they will fit.
I wouldn't like to say with confidence.
Thanks for the link :)
Mines a coupe, already had a bit of trouble nearly buying a set of 19" that were for a saloon - didn't realise they were different 😬
Using that guide the E63 wheels are 8.3mm further away from the suspension, is there a guide on what's an acceptable amount?
