Will a Later exhaust fit my CL?
cl55 amg
Manchester
CL55 AMG
Instead of going down the custom exhaust route. I would like to know if the later cl55 rear box's (with quad pipes) fit my non-Kompressor cl55 (2001)?
:) danny
Likely to physically fit under the car, might need some adapters for the pipe diameter. Will probably sound a bit "boomy" and there maybe loss in performance or economy due to not having the matched backpressure required by NA cars. Naturally you could cure this by fitting the supercharger ;)
I would love to fit a supercharger, but I'm sure it would cost a fortune! :) I wonder if it would be possible to cut the pipes off after the rear boxes and have them welded onto my boxes?
Worst case you could have off-the-shelf aftermarket rear box/boxes with AMG pipes welded on, the tail pipes are available separately or could be salvaged from an AMG backbox (shame though).
I can get the quad pipes for a later AMG for £300 second hand. Just need some help if its definitely possible?
As Shude says anything fits anything.. I had the CLK55 back box fitted to my 500 and then also removed the centre box.. it sounds lovely, as a V8 should do but not too obtrusive... I used my local privately owned Exhaust fitter (not the Humphries monkeys) and he did a really good job and not clamped but welded on very neatly..... If it was me I'd just get the two back boxes welded on.. Dont forget though you'll have to cut the bumper to fit the quads....
thanks for that the £300 is for back boxes aswell. What part of the uk do you live :) I always like using recommended garages..
