Will C43 brake booster may fit for 1996 C36 ???
tmck
C36 AMG
If C43 brake booster can be fitted for C36;and if that can do any good as a swap.
Thank you
I,m not 100%, but i thought about doing this to my pre-face lift C230K, IIRC correctly the duo valve would have to be moved slightly, also the bulkhead where the Servo fits "looks" different, as the Servo on the C43 looks to fitted slightly higher.
The c43 has ESP/BAS the c36 has neither so the electrical components will be idle
what do you want this new servo to do?
and as above in post #3.
i'm not sure it will have the effect you want, if your after better/stronger/sharper brakes.
Braided hoses will get you more result for less bodging.
