Will they fit????
merconian
IRELAND
C180 Esprit
Hi,will original alloys(16") off a 2003 CLK fit straight onto my 1994 C180?,if not,is there much "adapting" to do.
Thanks.
Sp!ke
Administrator
West London
SL500 & The Fart Car
I'm pretty sure the answer is Yes, no problems, just bolt straight on. Best get this confirmed by others here though as there is a chance I am wrong.
Another thing to consider is your wheel bolts, If you have standard steel wheels on your C180, you will need longer wheel bolts to fit the wheels. So make sure you get the bolts with the wheels as the set will cost you £60 from the stealership if you dont.
OP
OP
M
merconian
IRELAND
C180 Esprit
Cheers Spike,the bolts are with the wheels.I guess 225/50/16 will be ok for the rear?.How you doing with the Nokian's?,had mine on a month now,still very please performance v price wise.
Sp!ke
Administrator
West London
Should fit no problems...My Nokians? Yep V. Happy indeed definately made the right choice.
BaldGuy
Berkshire & London
Porsche + BMW + Mercedes
Will go straight on!!!!
My rims were on a CLK cab...
