Will this fit on TVtuner or Command?
No sir it will not it is 5volt power supply and will only work if you have an existing tuner as it has an RF output only, sure a 5.6 power supply is easy to make or buy
The little BUSH scart adaptors are tiny and 12 volt, and you can use them with the adaptor that Hugh put up on the forum and cost from£23 + vat
The hardest job is the aerial
Malcolm,
With some modding it is possible though?
