Will this Head Unit work on my W203 Merc?
Ironnike
C220
I found this head unit PART NO: A 209 820 53 89
Will this work with my 2001 C class W203?
Will be a direct fit or will I need to buy any adaptors or wiring?
Any help is much appreciated.
Hi Ironnike,
I believe that unit is from a CLK being part number 209, so it wont actualy fit!
As your car is pre-facelift you will need a Comand 2.0 unit, as that's a plug and play option, otherwise an extensive loom retrofit is required! i don't know how hard it would be but maybe an NTG2.5 retrofit would be a better solution as it is the most up to date option, with loads of extras you can do with it, but it is costly, so its all down to what you want to spend.
I would suggest contacting Comand Online, they helped me with my upgrade and it went flawlessly!
Hope this helps!
Hi Ironnike,
Hope this helps!
It is advertised as being removed from a w203. I don't know
Ok, well it might be from a C Class, its just the part number is from a CLK and i have never seen that unit fitted to any C Class before.
My main concern is your car is a 2001, with the older ISO style connector instead of a quad block connector, means this wont be and easy task, definitely not Plug and play. On the other hand a Comand 2.0 is plug and play and would be a lot cheaper to buy.
Have a read through this article;
http://www.mercupgrades.com/COMAND+Retrofit-article-1.html
it tells you everything about Comand and what fits what and whats needed to retrofit one into your car.
I hope this helps.
Never belive eBay ads!
AFAIK its for W209 and W211's only. Have you purchased it already?
Even if it will work with a W203, you have the wrong dash/wiring for it, you need the facelift dash for it to fit.
