Window motor problem in w210
poisas
Lithuania, Siauliai
Hi, in w210 window opening switch has 2 modes, manual close/open/ if you press more, then its fully open/close - after fixing some mechanical problem in the window mechanizm, this mode is not working anymore, only manual is working, we was take out the motor, and have it in hand, fully open close is not working, manual is working.
Any sugestions ?
is this ONBoard comp related ? or we are missing something ? :) i was open my door already 2times trying to found what is wrong...
W210 E250 TD .
Dont you just shut the window and when its shut keep your finger on the button for 5 seconds or so to reset it?
Lynall
Lynall
nop i didnot.. i didnt know about i need to do so.
bu i found one post that told to hold about 30sec in closing direction, so i did it and it start to work again :D
Waste of almost 30 seconds of your life. A couple of seconds would have been sufficient. ;)
Best fix of all a free one:)
Lynall
