Slk 230 1999.
Nearside 1/4 window will not raise or lower and is stuck halfway.
Looked inside the window rubber and reattached the bowden cable back onto the pullies,the regulator is trying to work and then meets resistance and the cable jumps.
The window appears to be very loose compared to the other side,so i am thinking it has come out of the runner,thereby causing damage to the cable.
I will need to replace the regulator assembly,quoted £150 just for the part.
Does anyone have experience of stripping the inside out to get to the window mechanism,indeed if a drawing is available that would make life a lot easier.
Cheers
jodie
Cheers
jodie
