ken crosley
firstly i have read all the posts on window tinting. my question is has anyone done it and is it a pig of job or what. was thinking of doing the rear half. can anyone talk me through it-- regards ken-- c180 esprit
RJIF said:did it on my c180 '96. tinted the rear door windows only though as the rear window is a difficult job as it is hard to get to (precuts may be available to make the job easier). doing the doors is not to bad a job but needs time and care to get a good result.
you have to strip out the doorcards, ext' window trim, window plate partition, remove main window plate from winder mechanism, remove corner window plate from door. clean both windows thoroughly both sides and follow the tint fitting installation instructions closely - time and care needed for good finish! rogue hairs and bubbles are a pain to get out and ensuring the water/suds solution isnt to suddsy is vital to stop bubbles drying out causing dry spots.
electric front windows were to daunting a task to attempt for me so left it at just the back door windows.
A friend of mine drove all the way down to London from Blackburn to get his M3 tinted at Pentagon, cost him a LOT. About a week later a corner peeled off one window and they sent a man up in a van to repair it, they were very apologetic and gave him some compensation for it. They seem to be very professional if nothing else.Mambo said:Pentagon are the daddies!
They are expensive but IIRC Maff can get a discount....
