the prince
Hi just had a new fault today and wondered if anyone had any thoughts. A few things to mention. I have had car parked up for a few weeks so thought i'd charge battery overnight. Disconnected as per manual and reconnected. All ok.
Started up fine.
Noticed water in passenger footwell :fail (unrelated i know) pulled up carpets and attempted to dry out carpet and sound proofing. Noticed box section in foam of carpet (ECU?)
Anyway as this is unfolding etc, i also noticed that when i went to open the door, window dropped around two inches, not the usual half an inch. Also when the door was closed it didn't close up again. The same fault also occurred on the passenger door. The doors were able to be closed back up to the top with the button, but when the door was opened again, they again dropped two inches. Any pointers on the problem/fix for this fault?
Started up fine.
