npuk
I needed to have a small chip in the windscreen repaired and also had a previous poorly carried out repair done by my insurers nominated windscreen repairer National Windscreens done back in March that needed sorting out. The chip was rough, still visible and not see through.
After spending time searching I came across a company called Glass Doctors who were recommended on a few car forums.
Glass Doctors UK Windscreen Repair not Windshield Replacement
Pictures attached. 1st picture of the repair National had done and the 2nd of Glass Doctors repair and how it should have been done in the first place.
The difference is amazing. The chip is alot less noticeable now and would probably be barely visible if I had it repaired by them in the first instance.
I would highly recommend them if they cover your area. David is a friendly bloke and explained exactly what he was doing. Quality of the work is top and the prices are good. They either bill your insurer direct or you will get a receipt and a form to claim the cost back from your insurer (assuming you have a fully comp policy with glass cover).
