Wing mirror indicators and adjustment
owlse
M3 Vert & E320 CDI
Hi guys
just bought this e320 cdi 2004 , lovely car and very clean , but found a couple of little niggles that will need sorting
first thing is there is no indicators working on the wing mirrors , plus the adjustment does not work on either side :(
they do fold when i push the button , but interestingly if i push the adjuster switches while its folding the folding freezes, then when i let go the folding process finishes
same on both sides :dk:
been looking on the web , and seen lots of mention of the wires braking , but i have not seen anything that lists both adjusters and indicators
thanks in advance
It is almost certain that the looms to the mirrors have broken wires in the hinge area. MB only sell the looms as part of the mirror assembly, and these are costly. If you get the car to a local specialist they will repair the wiring for you which will save you £££'s
i would go with wiring too , just surprised it would be both sides :doh:
will take a look see what i can find, if not i will find a local indy to sort it
More than likely the wiring as mentioned above, on some models it brakes the wiring to the adjustment motor aswell it's just that not a lot of people realise as they don't adjust there mirrors too often once they are happy with there position.
We repair these on a daily basis
thanks guys, will take a look :)
Definately wiring, I have fixed the same problem on my E-Class as well.
wish u was closer i would just bring it over to you guys :thumb:
We're are you located? There are some other good guys on here that have also set up independently that may be able to help.
I am in Sheffield :thumb:
