wingmirror has been hit......fuming
50pence
cardiff
w203 c180 classic
some **** has hit my mirror, luckily the mirror that 'popped' out is intact, a small hariline crack i can live with, but the clear indicator plastic bit is shattered......soooo, my question is, can i just repace this bit, or do i need a whole mirror?
As long as the fixings inside the mirror cowling are ok, and they probably will be, then you can get replacement 'blinkers'.
I changed one recently on my W220 as it packed in. Easy enough job once you figure it out !!!
I read your words...then I look at your avatar...freaky!!
ive had a look as how to get at it, i can see some clips and some sort of hook on rubber, guess its easy if you know what your doing, where can i buy the replacement, what would it be called? ill have a look on the bay
Slide the mirror cover off, and then the lens is just held on with small screws.
Don't bother with ebay for the lens, they're really cheap from your local MB dealer parts dept,
Some t**t did the same to mine. I got a new one from ebay - but it was a MB dealer off loading some stock, for £22.50 delivered.
I then watched of a few YouTube videos on how to do it, and it was a 10 minute job.
