be careful as this may cost a lot to put right if it goes completely regards jon ps , ibrar and shude are correct with the s and w mode descriptionCheers Shude, ibrar, it's just that I'm going to see one that the owner said was left in summer mode (in the winter) and it wouldn't shift gears properly, but he put it in winter, and it was fine again?
According to the seller, the modes are more to do with the 'box taking longer to warm up in summer mode, in the summer no less!
It will undoubtedly have a W/S switch.
The outcome of driving in standard mode during winter is potentially (increased? ) loss of traction when setting off in icy conditions.
W mode utilises a different reverse gear and either a different 1st gear or simply 2nd gear when in drive for a smoother takeoff.
?????????? walk a way if i was you, unless you can get it for peanuts, it sound like it will cost a lot to put right (IMO) regards jonHmmmmm
I haven't bought the car yet, but the owner has said that it was a really cold morning a month ago, and "it wouldn't shift gears" he called his mechanic (Merc technician) and was told to put it in winter mode, then all was fine?
It's got about 80k on the clock, full MB history, gearbox fluid has also been changed recently.
not sure but dont forget its an E55Well it's not too far away so I may still go and see it, any advice on thoroughly checking the 'box? Any tests etc?
According to the seller it drives perfectly now though?
I may be able to get it sub 6k? Worse case scenario, how much would a replacement gearbox be, fitted?
Hmmmmm
Actually this might not be as scary as it sounds. On cold days my car can be super-responsive and reluctant to shift up through the gears in the first minutes from start. In fact, my car tends to only shift as far up as 4th gear until the engine temp needle hits exactly 80 degrees, then it shifts into 5th.I haven't bought the car yet, but the owner has said that it was a really cold morning a month ago, and "it wouldn't shift gears" he called his mechanic (Merc technician) and was told to put it in winter mode, then all was fine?
