Winter Tyres Clanger
Dichtung
N.W.
W203 2.2Cdi
Hi Guys,
After reading all this spiel about winter tyres and remembering last winter`s fiasco; I bought (luckily for peanuts) 4 - 15" steel wheels from a W210 e200.
They wont fit! :doh: They will on the rear but not on the front. (MB2104000202) ET37
Mine`s a 300td Avant g 16" Ronals. ET41
I can only think e200s must have smaller front discs and or smaller calipers.
Can I ; Use 16" on the front with 15" on the rear?
Is that legal?
Will the ABS light come on?
Use them on my W203?
Bin them? :eek:
Hi Guys,
Is that legal?
Bin them? :eek:
Bad luck Ditchtung. I suspect the balance could be a big issue, notwithstanding any insurance claims. No doubt the BIG Boys will tell you what's a goer!
Try them on your 202...though you may have the same issue.
Thanks Sp!ke, Good idea, :cool:
I`ll try and estimate what thickness would be required.
Check your handbook for the correct 15-in wheel fitting
ET37 sounds like a rear but ET41 sounds dead wrong
I cannot get at the handbook but from what I remember each wheel size has a different ET. The handbook lists the correct assortment of wheel sizes available for each model. I do know that my E320 Av will take a 15-in wheel, in fact I think that's what the spare is.
I have 3 handbooks, interior; exterior and driving, and no wheel info in any.
Seems I need a "Technical Data" handbook.:rolleyes:
The fact that your 320 Av will take 15s is interesting.
Thanks Jefrs.
Ok I have the books today. Yes it is the Technical Data
And my bad, spare is 215/55R16 that's 16-in. pressed steel.
('cos it's an estate and it runs on the staggered 8J/9J 18-in AMG set)
FYI Spec for E320
summer tyres 215/55R16 93W
winter tyres 215/55R16 93H M+S
pressed steel wheel 7.1/2Jx16 H2 o/s 41
light alloy wheel7.1/2Jx16 o/s H2 41
summer tyres 235/45R17 93W
winter tyres 235/45R17 93H M+S
light alloy wheel 8Jx17 H2 o/s37
summer tyres 235/40ZR18
light alloy wheel 8Jx18 H2 o/s 31
Staggered AMG set - front - rear
summer tyres 235/40ZR18 - 265/35ZR18
light alloy wheel 8Jx18 H2 o/s 31 - 9Jx18 o/s35
nota - car has bodyshell modifications per E55 to take these
Spec for E300 Turbodiesel
light alloy wheel 7.1/2Jx16 H2 o/s 41
light alloy wheel 8Jx17 H2 o/s 37
spare wheel
The E290 Turbodiesel and E240 (petrol) and smaller do list 15-in wheels
Thanks for that jefrs.
I was beginning to wonder if my alloy wheels/calipers were original. :D
Digging a bit further, it looks like MB fitted two types of 15" steels on W210s.
And; sod`s law, I`ve bought the wrong one. :doh:
I'm surprised 15s clear the brake callipers.
They don`t; on my 300td AvG.
and here`s the mystery; I saw the car that the 15s came off; and it was an W210 E200. They had been replaced with really big alloys and what can only be described as innertubes.
The way forward as suggested by Sp!ke are spacers, and 20mms would fix it. Not ideal but should be ok in the snow. :(
Quite a few 16"alloys on Euromerc.co.uk, and 17's in singles and sets. One set of 16's for £99!
Just checked, a set of 16" Rucha's for £99.99, perfect for winter tyres.
Thanks for the search fb, and I`ll bear them in mind if I come unstuck with the spacer idea. Cheers. :thumb:
