Hi All
I have a strange new problem. I have a 2004 CLK 320 convertible with auto wipers on it, which have developed a starnge fault. When you set the stalk to OFF the wipers contiue to run. If I turn 1 click in to auto they work as expected. When in the auto position they wipe once when the car is started and then return to the seated position, if it rains they spring into life and work as they should.
However if I set the stalk to off they start working and just keep going until I turn off the ignition. Evidently not a major issue as can be left in "auto" mode and everything works, just a niggle that I would like to resolve. HAs anyone seen this before?
Read a few posts and can't see a resolution to this problem but in some of the other posts people mentioned faulty indicators ETC which could be the stalk. Mine works fine for the indicators ETC just the issue with the not truning off so I think the stalk is fine.
Many thanks
Paul
Many thanks
Paul
