Hi All,
I have a Japanese import 2004 Viano which has been converted to a campervan in the UK. It had a solar panel installed on the roof and the installers fed the cables from the panel into the same entry point that is used for the rear winscreen wiper cabling. I am having some problems with the voltage at the other end of this cable which feeds into the solar panel regulator and I have a suspicion that there may be a join somewhere in the cable but of course it is all hidden. Can anyone give me a steer on where the rear windscreen wiper cable is routed? I assume there is some kind of (planned) space through which they are routed. I think, from the little that I can see, that it is mainly routed just below roof level and then drops down to floor level in the 'strut' which houses the passenger seat-belt mechanism. I have tried to remove the plastic cover but it is resisting my endeavours and I do not want to break anything. Any help or suggestions gratefully received.
Bob
Bob
