Wistling sound and oil in intercooler
Black c320 said:
If there is a hole with air escaping then yes you need to replace the intercooler.
How bad is the oil in intercooler?
The oil is just from blow-by gas and will be variable depending on mileage and engine condition..unless a turbo seal has gone allowing oil into the intake,
however if you have a hole in the intercooler that is leaking oil you need to repair or replace it..that is probably where the whistle is coming from.
I suggest you get it inspected by a mechanic before spending cash on parts.
Is it Groundhog day today?
Must be!
If the intercooler's split, change it or fix it temporarily with epoxy putty after a thorough clean with brake cleaner or something similar....
If you haven't started pouring in litres of oil to keep the level correct and people behind you aren't choking when you accelerate away from them, your turbo's OK and it's just a normal level of contamination in the cooler from the crankcase vent.
Paul
Thanks to all of you guys for your help I got a new intercooler today an going to replace it tomorrow
The WISTLING noise is a turbo charger bearing been told my local mechanic, also he said it can go down at any time. Is that a big problem that better to sort out now or shall I wait till it will go down and change a turbo charger? Thanks
