Geoffjake
Looking for advice ,I was checking the injectors for ' black death ' when I noticed one of the injector clamping bolts had been replaced with a bigger bolt ,I know these bolts are stretch bolts and you must use new stretch bolts ,my question is should I re-use this bigger bolt or replace it , these bolts get stripped out if the bolt hole is not properly cleaned out and the new bolt can bottom out on rubbish at the bottom of the bolt hole
