Worst Engine Ever Made?
you will be familiar with this video then. ;)
1:38 shows how the head comes off....
This explain it in detail (same chap):
Only in my case, the head was do seized, that the removal tool simply stripped the the threads in the alloy heads.
What eventually did the trick, was a panel bearers' hydraulic jack set, borrowed from a friend's garage, after lifting the head about half inch. Something similar to this:
10-ton-separate-hydraulic-jack-10T-sheet-metal-hydraulic-separation-of-the-top-vehicle-maintenance-tools.jpg_Q90.jpg_.webp
The year was 1985, BTW, and the car was an 1979 Alfetta 1.8.
Makes you realise how important the state of the antifreeze/coolant composition is with these open decked blocks!
