H7
car is w221 s320 cdi wirhout xenon, dipped beam h7 High beam h9
My h7 socket was Melted and damaged, and i Saw it has 1 Yellow wire and 2 Brown wires, unable to find the correct part number i purchased The socket for w210 h7, This has 1 Brown 1 Yellow wire.
The Melted socket was causing bad connection and Therefor canbus obc errors , in my case airmatic lamp and sometimes airbag lamp for 2-3 seconds.
Mechanic Said he Can cut OFF Old connector, splice The 2 Existing Brown wires together and then splice Them onto The new connectors single Brown wire without problems.
He did that, but now The airbag lamp is On constantly! I dont know if i should change The h7 connector On The other side The same Way aswell, or what The problem seems to be?
There Are no led Bulbs installed.
Fog light assembly is slightly Melted aswell from
Bad Bulbs, but The bulb Can stay in place and connector / wiring looks completley undamged!
I have hid installed , they were expensive and with canbus for new german cars.
I was BTW unable to find a connector for W221 with 2 Ground wires and 1 Yellow wires
I am thinking OFF adding Load resistors in The h7 Bulbs - and installing led Bulbs with canbus + Load resistors in The Fog to imitate a problem free scenqrio to cars computer...
Also, i know The srs and airmatic lights Are canbus errors since i once had led Bulbs installed in license and parking - same errors Came, switched to original - errors gone!
Going crazy please help
My problem started when i used some halogen xenon look Bulbs, they Melted my h7 connector (one side loooked fine though) and my Fog Light assembly, initally when i Removed The Bulbs (that were stück because OFF melting) then The errors began!
