X164 front brake hoses
AndrewOl
Romsey
E350 A207
Hi, 2006 GL inspection advised that front hoses were replaced. Is this a straightforward job or is there anything I should look out for when doing this one myself?
Well if you can bleed brakes you will be fine . Me i would take mine in to be replaced, its quicker , and i will have a brake fluid change at the same time . Biy instead of rubber brake hoses i would have stainless steel braided flexi hoses fitted.
