Thinking of changing the bush on the front wishbone as the car feels a bit loose when going over bumps etc. It is a 2006 with 150K on the clock so it probably fair to say there is quite a bit of wear in the bushes. The top arm has been replaced and the arb drop links seem fine. Does anyone know if this control arm bush can be replaced without taking the whole wishbone off? The bush I'm refering to is the one with it's own housing that pushes over a spigot on the wishbone rather than the other one which is pressed into a housing in the wishbone. I think the bolt that connects the bush housing sets the camber for the front suspension.
Cheers
Andy
Cheers
Andy
