- Mar 11, 2013
- Location
- South Bucks
- CLS63 SB, SLK55, Cooper S, Triumph Sprint (Bike not Dolly...),
Doing some checks on the 2014 CLS 63 today, the iCarsoft check on the aircon pressure (must be high side) never rose above 10.2 bar (just after I cranked it down to 16 degrees from 20) and dropped quite quickly to about 8 bar.
It takes a lot longer, because it doesn't blow nearly as cold as the CLS 350's almost-instant instant Arctic blast, to get the temperature down. ISTR the W210's aircon, with built-in OBD, ran at something like 14 bar.
There were no fault codes. Does anyone know whether the pressure readings I obtained indicate the system is low on refrigerant?
