Gipsyracer
- Sep 24, 2014
- 2007 E280 Avantgarde Estate
Extensive online searching hasn't revealed a solution to this one, so all advice gratefully received...
My 2016 CLS shooting brake tailgate is stuck in the closed position, but not fully closed, the mechanism has not pulled it down to the second stage closing and it will not latch by pushing down manually. As far as I can see, there is nothing jammed in the tailgate to stop it moving to the final position. And it won't open, either.
I'm confident that I will be able to diagnose the fault, once I've got the hatch open. Trouble is, it is stuck closed so you can't get at anything to check it. I've prised the trim panel open so I can stick a torch in to see what is going on with the aid of an assistant on the outside of the car.
Operating the tailgate release button near the number plate, I can hear a click as the solenoid actuates, but nothing can be seen moving near the latch mechanism, even if the hatch is held closed to take the pressure off the mechanism.
The tailgate motor operate, but just strains against the hinges.
How can I release the latch, to open the tailgate?
