davethemus
was thinking of upgrading my lights to hid, has anyone had any experience, good or bad, or any recommendations?
Well, the proper replacement OEM HID headlamps are quite expensive from memory (£500-600?), unless you can find some secondhand ones.
If you're talking about the 'HID kits' that you find on eBay etc, it's probably worth a forum search as there were some lengthy threads on them..
Will
think i'll bide my time and wait for a second hand set to surface, the conversion kits seem a bad-head.
people will flame you on here for them being too bright and illegal etc etc but i dont think they blind me any more than every other car with halogens that are out of adjustment coming the other way!!
My mate has done a conversion to his 51 plate CLK using a Bosch aftermarket kit. The results were impressive in terms of how bright the lights are and the illumination they provide - much brighter than my std OEM HID lights.
However, fitting HID to normal light systems seems to result in massive side scatter and glare from the lights that for oncoming drivers is not very nice. On mine unless your are directly looking into the 'beam' there is no dazzle which is what is intended by MB.
The BOSCH kit contains headlamps, ballasts/control units and all bulbs. Does not include any levelling parts except standard vacuum levelling and does not contain headlamp wash/wipe.Hi,
I believe the BOSCH kit that Shude is on about comes complete with controllers.
For info, I took the the part number which is mentioned to BOSCH and it is still a current number, though the description they have for the number is a bit vague.
If you get an original set from Ebay or a breakers yard, you need the controllers as well.
Is this just the 'ballast'? Or something more? I assume you could use 'generic' ballast units if that's all they are.
I have installed an aftermarket kit in mine and the improvement is massive
