esox
- May 15, 2003
My xp system restore goes through the motions,but after restarting i get"unable to restore,no changes have been made"
Whats up?
Whats up?
timmy said:Don't reinsatll XP, you will lose everything unless you back it up.
masqueraid said:Suspect it's a bit more serious than that. If the restore point has become corrupted XP won't use it & either a repair or reinstall may be necessary.
A lot depends on why the Sytem Restore is being used & if there's another way 'round.
Often when SR fails it describes why. If there's no clue given it is probably a damaged file.
Some help is offered here:
http://support.microsoft.com/default.aspx?scid=kb;EN-US;302796
masqueraid said:The 'oldest restore point' is simply that. When you run the wizard you will get a selection of dates that are available. Unfortunately there is no guarantee that they will either restore successfully or solve your problem.
System Restore is a dramatic choice to solve an XP problem. Why have you chosen to do this? There may be a more simple solution.
