Years ago had an old Ford Pop 100e
Discussion in 'OT (OFF Topic) Forums' started by meoldbangar, May 31, 2013.
  1. meoldbangar
    meoldbangar Active Member
    75
    Apr 1, 2013
    Car:
    C180 W202
    Years ago had an old ford pop 100e
    Head gasket went, still got me home 98 miles later
    Side valve engine, so simple to repair, 8 bolts , job done (after a clean)
    Brakes, doddle to replace
    Starter end worm gear to replace- piece of cake
    Piston blew its top off - to replace - a doddle
    The question I would like to ask - is there a modern car in the same league
    Because in my opinion the 100e was a magic motor for the DIY mechanic
    Your thoughts on old cars much appreciated
  2. renault12ts
    renault12ts MB Club Veteran
    15,960
    Mar 5, 2009
    Car:
    2005 W215 CL500.
    Years ago had a Morris Minor...you want to lower the front ...just strip the suspension and move the torsion bar round a notch. About an hour.
  3. Chrishazle
    Chrishazle Hardcore MB Enthusiast
    3,380
    Nov 13, 2008
    Nr Ashford, Kent
    Car:
    2008 S204 C220CDI Elegance Estate Auto, 2008 R171 facelift SLK280 Auto.
    Years ago mate of mine had an MM Morris Minor - side valve engine - and another mate was about to scrap a Minor with a good 803 OHV goldie engine - so between Friday evening and Sunday evening Steve and I swopped engine, gearbox, prop shaft, back axle, rear suspension, front suspension and towed the dead one to the scrappie using Steve's now OHV MM!
  4. Scott_F
    Scott_F Hardcore MB Enthusiast
    4,091
    Mar 12, 2010
    Anything with a BMC A or B Series engine will be very straightforward to work on under the bonnet.
  5. Chrishazle
    3,380
    Nov 13, 2008
    Nr Ashford, Kent
    Car:
    Providing it's not got a warm cam and twin SU carburettors - as my son's MG Midget had. Whoever had the engine uprated had the wrong needles in the carbs. We eventually found a man who knew what he was about, and he transformed the car! Basically though, you are correct - 2 spanners and a screwdriver, and an hour later the engine is on the garage floor in pieces!!
  6. jotter22
    jotter22 Hardcore MB Enthusiast
    2,250
    Apr 23, 2013
    Gravesend,Kent.
    Car:
    CLK 320 Avantgarde convertible
    and then on the 6th day god invented fuel injection!
    2 people like this.
  7. Palfrem
    Palfrem Hardcore MB Enthusiast
    2,957
    Aug 11, 2005
    Solihull, near Birmingham
    Car:
    W124 E36 AMG, G 300 GEL his, SLK 200 hers
    ..and it was good
  8. trapperjohn
    trapperjohn MB Club Veteran
    7,316
    Nov 19, 2008
    Lancashire
    Car:
    124 300D 24V Estate
    My Dad's first car was a 100 Ford Pop. TMH 949. Happy memories of trundling off to Southport in it. I think he drained the rad in winter every night as antifreeze was too expensive. Happy Days.
    1 person likes this.
  9. grober
    grober MB Club Veteran
    27,630
    Jun 22, 2003
    Perth, Scotland
    Car:
    W204 C200CDI Estate
    I miss the the old choke cable held open with a strategically placed clothes peg though and the vacuum operated wipers made overtaking in the rain interesting! Water pump? --- what's that anyway?
  10. nigel cross
    nigel cross Hardcore MB Enthusiast
    2,414
    Jan 8, 2005
    Surrey
    Car:
    W164 ML350 Audi S4
    What about the hand pumped screen washers?
  11. renault12ts
    15,960
    Mar 5, 2009
    Car:
    2005 W215 CL500.
    I learnt to drive in a 105e.
  12. grober
    27,630
    Jun 22, 2003
    Perth, Scotland
    Car:
    W204 C200CDI Estate
    Double declutch into first gear. - Oh wait ------it had a 4 speed box and OVERHEAD VALVES :ban:
  13. artyman
    artyman Hardcore MB Enthusiast
    2,105
    Mar 4, 2011
    Hampshire
    Car:
    C 200 CDI Sport
    That brings back memories, the last car I had the cylinder head off was my old Hillman Avenger GL, since then it's just been oil swaps, yer just don't get to tinker in the garage these days, gives the missus far too much time to find jobs for you :(
  14. renault12ts
    15,960
    Mar 5, 2009
    Car:
    2005 W215 CL500.
    My father's first car was a 1959 Beetle...it had no washers at all!!
  15. Orwic
    Orwic Member
    58
    Sep 5, 2008
    London (and sometimes N Wales)
    Car:
    E320 cdi Sport (C240, retired)
    Morris mini minor 850 countryman (mine was a 1967 car): not bad to work on. Not that many tools needed. Refurbished valves, wheel bearings, cv joints, wheel bearings, dynamo, starter motor, brakes - all fairly easy jobs. Bypass hose a tricky job though - and quite often sprang a leak. Points replaced routinely to keep performance up to scratch. Foot operated washers, with a huge reservoir (a whole pint of water!), with non self parking wipers. Heave on the handbrake too hard, and it broke off (had to get mine welded back twice). Brakes faded dramatically - could be scary at times. No synchro in first (and first was needed on steep hills with 4 people inside). Sliding windows. Car leaked in very wet weather, and you could end up with a gallon of water in the floor (cured by drilling drain holes). Fitted my own radio (dry cell battery radio on the back seat with a window-mounted antenna). Also fitted a very loud horn (and still wish i had one as loud on my current car). One thing I remember was that it was very reliable - started fine no matter what the weather. Only let me down once. Parking in a tight spot once, i was turning the steering wheel and it failed - just turned round and round in the car but nothing happening on the road wheels. called the AA and the guy tells me i need a new steering column. Main parts agent nearby - the AA man waited while I went over there and bought a new one and he fitted it on the spot. Finally got rid of it in 1977 (not without a pang of regret, I admit).
    Orwic
  16. Aitch55
    Aitch55 Hardcore MB Enthusiast
    137
    May 21, 2012
    Beds.
    Car:
    SL55
    Me too :) My Dad's. 103 MTM bought new in 1964 and bright yellow.
  17. Aitch55
    137
    May 21, 2012
    Beds.
    Car:
    SL55
    You missed the push button starter mounted in the floor :) and pudding stirrer gear lever (pre Cooper remote gear linkage)
    And spluttering to a halt whenever it encountered a puddle of any size :(
    Great little cars. :)
  18. baxlin
    baxlin Hardcore MB Enthusiast
    897
    Apr 26, 2013
    Home Counties
    Car:
    Volvo C70 and JZR 3 wheeler
    My first car, when I passed my test aged 17, was a 1937 Morris 8 Tourer, given to me as an MOT failure. New pair of reflectors (2/6d) cured that bit, and a strip down of the front cart springs, degreasing them and reassembling them extra tight - new hangers were unavailable - reduced the steering play to an acceptable level. Job done!
    The next car was a 1953 100e Anglia, bought as a rebuilt write-off! It used a pint of oil to each gallon of petrol, pouring bright blue smoke out of the crankcase breather tube, and into the car..... So I pushed a piece of garden hose over the breather pipe, routed it to the back of the car into a bit of metal pipe - hey presto twin exhausts, both belching clouds of smoke.
    Both of these were in the mad mid 1960s
    Now the antidote to the computer-filled ultra sophisticated C220 is my self-built 3wheeler powered by a twin carbed 1978 Honda CX engine.
    Malcolm
  19. OP
    OP
    meoldbangar
    75
    Apr 1, 2013
    Car:
    C180 W202
    Vacuum operated wipers ! Happy Memories
  20. MD5
    MD5 Hardcore MB Enthusiast
    2,367
    Oct 15, 2008
    Car:
    wme451 a124 r129 s211 r230 w251
    So did I - it was the first car I ever bought. I was 17, and I think the car was only a couple of years younger than me. Often referred to as the "E" type - followed by "100 E type", with a Sean Connery style intonation!
Share This Page
