Yellow triangle?
Discussion in 'Engine' started by dunegold, Sep 9, 2011.
  1. dunegold
    dunegold Member
    45
    Sep 6, 2011
    Hi
    Can anyone help please?
    When i turn on my merc a170 a yellow triangle appears for a couple of seconds and it says LIM (i think) what does this mean?
    Thankyou
  2. timwood2000
    timwood2000 Active Member
    596
    Feb 17, 2008
    Bromley, Kent
    Car:
    R320 CDI SE LWB '07, BENTLEY CONTINENTAL FLYING SPUR MULLINER '06, FIAT 500 LOUNGE '58 & BMW R1200RT
    This will be be speed limiter. On the cruise control stalk (usually on the left of the steering wheel), you can push it in to set the speed limiter and push it again to turn it off.
    There should also be some kind of display on the centre cluster of the dash showing what speed you have (accidently?) set.
  3. OP
    OP
    dunegold
    dunegold Member
    45
    Sep 6, 2011
    Ohhh ok thankyou!
    Doh! I will check i blame the husband he drove it last!
  4. clk1
    clk1 Active Member
    64
    Sep 4, 2011
    Hull
    Car:
    Brabus D6 E320cdi with AMG body Kit / 1992 CE220 / 2000 CLK 230
    i did the same the wife was not happy
  5. BTB 500
    BTB 500 MB Club Veteran
    18,838
    Aug 7, 2005
    Berkshire
    Car:
    R129 SL500, W639 Vito 120, S203 C230
    Not sure about the A Class but you can often set an overall maximum speed through the cluster menus too (typically for when you have winter tyres fitted). That's always good for a laugh :D
  6. effbee584
    effbee584 Active Member
    524
    Mar 5, 2011
    Norwich
    Car:
    Jag XF 3.0S and 10 yr old Micra 1.2 auto with Air Con.
    Yes, I now consider the LIM function a hazard in itself.
    Some years ago, I set it at 52K in a heavy road works area (50K limit) on a Belgian ring road festooned with cameras, and used it for many miles. When I reached some traffic lights at the start of the standard 100K zone, I was at the front of a queue trying to overtake many lorries and could not understand why the car did not accelerate, lots of flashing and tailgating from behind, don't blame them really.
    I have not used it since, nor will do so again.
  7. OP
    OP
    dunegold
    dunegold Member
    45
    Sep 6, 2011
    Can someone tell me how to turn it off please :(. In idiot terms! Cant find anything in manual.
    Thankyou
  8. Bobby Dazzler
    Bobby Dazzler MB Club Veteran
    16,119
    Jan 21, 2005
    Mittel England
    Car:
    ML AMG-line Black Series
    The speed limiter (and cruise control) is usually controlled by the 'thin' stalk near the indicator stalk. Push it in - in the same motion as using a snooker cue - and that will turn the limiter off (if it's on).
  9. OP
    OP
    dunegold
    dunegold Member
    45
    Sep 6, 2011
    Just found it in the manual now!.
  10. OP
    OP
    dunegold
    dunegold Member
    45
    Sep 6, 2011
    Thank you. Will try that.
  11. DRBC43AMG
    DRBC43AMG MB Enthusiast
    1,079
    Mar 15, 2010
    Switzerland, Sion (VS), the canton of mountains, w
    Car:
    99' C43 AMG "T Rex", 00' Renault Twingo1, Ultima Sports Can-Am
    If I recall, it should disengage if you push the accelerator to beyond the kick down point.
  12. Dryce
    Dryce MB Enthusiast
    7,345
    May 17, 2006
    Car:
    Trouble is that a driver who knows little of the speed limiter may also be the sort who never presses down past the pressure point.
  13. OP
    OP
    dunegold
    dunegold Member
    45
    Sep 6, 2011
    Now we are not sure if it is on!
    Ok so when i turn the key and start ignition it comes up with yellow warning triangle and just under it in yellow it says LIM only for like a second...
    When i push the stalk in a yellow light on the stalk turns on push it again and it turns off...
  14. Dryce
    Dryce MB Enthusiast
    7,345
    May 17, 2006
    Car:
    That's presumably just the light being tested on startup.
    Light on the stalk indicates it's active if it's illuminated.
  15. OP
    OP
    dunegold
    dunegold Member
    45
    Sep 6, 2011
    Thankyou!.
    Thought it might be that..feel like such a fool now!
    Sorry am a new car virgin! Far to technical for me.x
  16. Dieselman
    Dieselman Banned
    34,206
    Jul 13, 2003
    Car:
    Peugeot 403 Convertible
    Is that something else you need help with...
  17. OP
    OP
    dunegold
    dunegold Member
    45
    Sep 6, 2011
    No all ok .. Well all my instruments seem to be in good working order! :)
  18. OP
    OP
    dunegold
    dunegold Member
    45
    Sep 6, 2011
    Forgot to add ... Bodywork also good! lol
    1 person likes this.
Share This Page
