- Jul 12, 2011
- Location
- Near Salisbury
- MX5 1.8 Sport, Range Rover 5.0 SC, BMW X1
Yes, I believe they have a Plastic Pipe that is attached to the Drain Hole that has to be pushed out of the way to allow draining.
Of course you have to remove the Sump Pan to put it back into place so as to get the correct level when refilling. (Although you would have to remove the Sump Pan anyway to change the Filter )
No idea why it changed, the procedure for the 5 speed seemed quite simple!
