Yet another W211 2007 boot water leak
jlb22
E Class
Has anyone had this in their W211 mine is a 2007. There is a pool of water along the edge in the gap each time it rains. What is the likely culprit? Many thanks everyone
Posted 2 weeks ago?
Posted 2 weeks ago?
Hi thanks yes it's not leaking into the spare wheel well, it's pooling in the gap shown between the plastic trim and the edge. I was wondering if anyone else has had this. Was it the brake light leaking?
On my 03 E55 water was getting in through the third brake light, fixed with some very pricey all weather clear silicon, only just done the fix so all dry at the mo and fingers crossed.
Great thanks Matt I will check there
This was my W211 leak
I am taking it to an independent they are putting a smoke machine in the boot
It’s normally leaks From the high level brake Light , either/both of the other main rear lights or the side drain strips
Many thanks. I never had this on my w212 or c class, it's a bit annoying but I hope they sort it
