Surf Blau
Recently I decided to install a Comand 2.0 unit in my car. It is of course a 163-unit without Can-Bus. I also opted for the FiberOptic (FO) CD-changer, both because the CD-slot up front is used by the navi-CD, but also because I heard rumours saying that the laser would wear out sooner due to use of regular CDs up front - better to be safe than sorry, right?
Since the Comand is a double-DIN unit it won't fit all cars - luckily the W201 is one it will fit!
Here is a pic of how it used to look (This CD-player is for sale BTW):
The old CD-player was removed, and the modifications could start! The map-pocket was cut to house the Comand, as was the lower centre console since this was too high in the back, doing so that the Comand couldn't be pushed all the way in.. Extra wires run were: Speedpulse from the speedometer, FO-cables to the CD-changer, antenna cable for the navi-antenna, as well as a signal-cable for the electric antenna. The navi-antenna was placed under the rear-deck. Both the antenna cable and FO-cable were a bit too long, so these are looped underneath the rear seat.
