- May 10, 2006
- Location
- Preston, Lancs
- S204 C220CDi Sport ED125 (Mr) Kia Picanto Domino 1.1 (Mrs)
I did wonder that, but in the past when a back-up bulb was used, got a message. Will do a physical check anyway - thanksI seem to remember (I may be wrong so apologies if I am) that some models had a "back up" bulb which was used when the normal bulb blew so that the rear lights still worked. Have you actually physically checked the bulbs to see if any have blown? As I say above, sorry if I'm talking complete rubbish.
Have a look at the grounding for the light clusters whilst you're at it; although I'm not sure if that was as much an issue on face lift 204s as pre-facelift.I did wonder that, but in the past when a back-up bulb was used, got a message. Will do a physical check anyway - thanks
Yes the CLK 209 has that too....took ages to figure out that the car has switched over bulb use........I seem to remember (I may be wrong so apologies if I am) that some models had a "back up" bulb which was used when the normal bulb blew so that the rear lights still worked. Have you actually physically checked the bulbs to see if any have blown? As I say above, sorry if I'm talking complete rubbish.
