Blackbenzino
Hi guys, new member looking for some advice, I have a 2009 w211 e320cdi sport om642, had the bucking and jerking with limp mode a few times intermittently and able to restart and be ok again, the other day it did it and I got engine light on, took battery off for 15 mins put it back on and everything OK again, it did it again a couple of days later on way to work a late shift intending to take battery off again the next morning but it cleared itself overnight, the next day after overtaking it went into limp again, switch off and back on drove ok but engine light back on, took it to my mechanic and plugged it in to find the following faults 2510 check y77/1 boost pressure reguator positioned signal fault, 2032 check g3/2 o2 sensor upstream of kat voltage too high, 2616 check b60 exhaust back pressure sensor control variation- exhaust back pressure is too high, 2513 check m55 inlet port shut off motor positioned signals fault, I did the easiest thing and opened the turbo actuator to find all connections look OK but there is quite a bit of play on the arm/worm gear. How much play is acceptable? The link to the turbo vanes moves very freely without any resistance, should there be any resistance? Also how common is it for swirl flaps to become detached as I go on holiday in 5 weeks time and can't afford to do any repairs until I come back, sorry for the long winded post and thanks in advance for any advice.
