https://translate.googleusercontent...c.html&usg=ALkJrhhY2dKSopRlpLIsZwX8jHryvvbxFA
according to this rather crude translation there were 3 types of fuel pump
so I may have misled you.
https://translate.google.co.uk/tran...ichacht-forum.de/read.php?1,53484&prev=search
e.g.
Hello,
So Bosch said:
250CE 4.69-3.70: Fuel Pump 0580970002
250CE 4.70-9.70: Fuel Pump 0580970004
250CE 10.70-4.72: Fuel Pump 0580464005
These are roller vane pumps.
0580970002
Roller vane pump for petrol promotion, without a filter, 2 hose nozzle diameter 8 mm for printing and Ruecklaufanschluss, 1 hose nozzle diameter 10 mm for suction, Permanent Motor 12V 40W power input, screw side
Type 2/120 CP 40/12/1
replaced by 0580970004
Flow rate min. 100 l / min, max. 820 l / min
Pressure 2.0 bar
0580970004
Type 2/120 CP 40/12/2
Armature shaft diameter 8 mm
all other technical data like 0580970002
Replacement for 0580970002
0580464005
Roller vane pump for gasoline promotion with pressure regulator without filter, Permenentmotor 12V 40W input power not bored with flat terminals without mounting clamp, medium nozzle on the pump when the pressure port 1 Motorgehaeusedeckel, for Durchspuelung
Type DG 2/120 CP 40/12/15
Flow rate min. 90 l / min, max. 750 l / min
Pressure 2.0 bar
Wafer with second pressure groove and with overflow valve, hose nozzle diameter 12 mm for suction port side of the engine cover Pressure port with hose nozzle diameter 8 mm
The first two are clearly among themselves interchangeable. The last has other connections.
Mercedes does not distinguish Year but after FGST No .:
- To 014 884: A0010917401
- From 014 885: A0010917101
Probably corresponds to the first so the Bosch ... 002/004, the second of Bosch ... 005th
Used lists of Bosch pumps:
0580970002:
0580970004: MB 250 CE (4.69-4.72), MB 280 SEC 3.5 (1.70-12.71), MB 300 SEL 3.5 (1.70-7.72)
0580464005: many MB D-Jetronic from approximately the end of 1971 (W107, W108, W114, W116)
