CreosoteChris
Cross-post – apologies if I’m bending the rules here – but I’m not really sure that the previous location was entirely appropriate - asking EuroCarParts for advice on sourcing a TB from one of their competitors
http://www.mbclub.co.uk/forums/2015220-post933.html
Hello – I’ve owned my 93 220CE for a few months now - so a relative newbie - and have just hit my first properly serious problem with it. As it looks like it’ll be expensive to fix, I’m looking for some second opinions / advice…
Without warning the idle speed suddenly dropped to a level where the engine was just about staying alive, but popping it into gear (car is an auto) stalled the engine. Managed to get it around to the local mechanic who took a look, reported that:
-He’d adjusted the idle speed to make the car less likely to stall, more capable of being driven
-I needed a replacement throttle body
The car is currently useable, once it’s on the move and the engine warms up (but getting away with a cold engine takes a few mins of warm up before it becomes possible). Trawling around the forums, I see that TB failure is a pretty common thing for aged W124s, so I’m pretty confident my mechanic’s diagnosis is right, and I need to look for a replacement – do you guys agree?
Anyway, if I’m facing the prospect of getting a replacement, then I’d like to make absolutely sure I get it right. The current TB is labelled as per the attached pic, with part numbers on the label as follows:
VDO: 408.227/110/002
Mercedes: 000 141 70 25
Tried calling Dronsfields (very big Merc breaker a few miles from where I live) who advised it’s a very common failure, and they have none.
I guess I could go for a BBA Reman refurb job, currently quoting £165 (though I note they designate some units beyond repair)
My other option is this ebay listing for a new item – expensive, but not the same sort of eye-watering expensive as the other similar units listed on ebay. The compatibility details with the ad report that it’s suitable for a 93 220CE (but does not mention further details - mine is auto, no cruise control). However , the part number is listed as 408-227-111-003Z, not 408-227-111-002 as per the label on my current unit
This page appears to indicate that the two VDO part numbers are interchangeable, and equate to the same Merc part 000 141 70 25.
Does anyone have sufficient familiarity with the vagaries of Merc and VDO part numbering to advise on this? It’s about to cost be a pretty big wodge of money, so all advice appreciated.
Thanks, Chris
93 220CE, auto, red / black leather, 101k, Manchester
Thanks, Chris
