StuartMB
I have a 2017 WDF447 111 Vito 1.6.
I bought it a few months ago, one owner, 35k miles. However, it smokes under load and between gear changes and doesn't run right on the motorway. I popped it in the German "specialist" garage near work. They decided someone had removed the innards of the DPF and remapped it in the past, and that is why. It shows no fault codes relating to the DPF or much else. My plan was to put a new DPF on, have the map put back to standard, and go from there. This seemed beyond them.
So I put it in Dronsfields, who know what they are doing and have a Star machine. They confirmed the previous diagnosis but said the remap could only be overwritten if there is a newer version of the software available, which there currently isn't. The only other option would be to change the ECU, which is expensive and they are back order with no ETA anyway. It seems just putting the original map back on it isn't something the Star machine can do. They suggested selling or PXing it as fixing it may be prohibitively expensive.
So I am here to ask the good folk of the forum for advice on this. Is there a 'back door' way the original map can be restored? Is a new ECU the only answer? People sell used ECUs on eBay, someone must be able to reprogramme them. Looking on Google, every man and his dog seems to do remapping, and I have no way of knowing who might be competent and who might not be. My first instinct was to return it to standard, but I am not particularly bothered if I have a DPF or not, I just want a van that runs right and doesn't smoke under load or when you are giving it some wellie.
Can anyone advise on the best course of action, please?
