De-ionised or not Norman, I hope you have plenty water on hand as you are no doubt about to be well and truly flamed - for talking sense!!
I know it is a little rude to threadjack, but as rudeness seems to be no bar to posting on some current threads.... Do you suppose the turbine extracts usefully energy from the steam present in the exhaust, or would it see the same energy were the water/steam not present, through a higher temperature in the exhaust products alone - assuming the turbine could withstand the additional temperature?
As to whether the turbine extracts extra energy from the additional water vapour, it's difficult to say, as I think that it's a matter of swings and roundabouts.
Logic seems to say that there is additional energy available because of the increased mass of water vapour present. However, it seems that water injection reduces the peak temperature of combustion and thus of the exhaust. Hence we have, possibly a higher exhaust mass flow rate but at a lower temperature - swings and roundabouts. I wouldn't like to say without some testing.
However, most turbocharged applications have more than enough energy available to give maximum required boost. When boost needs limiting the waste gate opens and exhaust is diverted past the turbine.
My GT4 reaches max boost (approx 1 bar) from about 3800rpm up on full throttle. I suppose that means that at any speed above 3800rpm exhaust energy is being dumped through the wastegate. I can't, therefore, see any realistic gains in increasing exhaust energy - unless you are just trying to extract the absolute maximum boost from an undersized turbo!
An interesting thoughts arises here! With a turbo charger you are only compressing as much air as you need - when you have sufficient pressure you efffectively don't drive the compressor any more, i.e. you dump exhaust. With a positive displacement compressor once you have sufficient pressure you dump the excess compressed air . You supplied power to compress this air and consequently heat it but then you just throw it away!! Does this mean that a turbocharger when providing boost is more efficient (i.e. produces lower temperature air) because it isn't having to compress air which is then thrown away? I don't know!
If we go back to the meat of the thread, StavFc was asking if anyone had data on the inlet temperatures of a C230K. Not an obvious question to ask for most people but his experience and knowledge throws this up as a query - and quite rightly in my opinion.
However, let me postulate that I have some of the figures he is requesting. What do they mean? For them to be relevant to resolving his problem he must have his own set of figures. How comparable are they? They really need to be compared at a set speed and load (steady state) or under a rigourously controlled cycle, under known conditions of ambient temperature and pressure and relative humidity.
Let us now assume that these hypothetical figures show that he has a problem of a high inlet temperature. What can be done about it?
As the question was asked about a C230K it isn't unreasonable to assume that any solution must be practical for an every-day road car. Possibilites appear to be:-
1) Clean the inside and outside of the intercooler - laborious but very cheap and should recreate original performance.
2) Fit a larger intercooler. Lots of work and not necessarily cheap.
Beyond this I just don't know. Intercooler water spray and/or water injection are, in my opinion, not practical for a daily driver.
As a consequence, my only advice to StavFc is, if the car doesn't perform as you think it should due to intake system anomalies, change it for one that does UNLESS you want to spend lots of money and lots of time tyring to resolve the problem.
But.... it's only my opinion - I would be very happy for anyone to show me where I'm wrong!
Finally, thanks to StavFC for prompting this interesting discussion. It's great to have people like him contributing his knowledge and experience which are outside the sort of thing that we normally see in these forums.
