GrandEd
Hi Again Forum,
About six months ago, I got some helpful advice from Forum - Coincidence or something I’ve done - electrics playing up
The short version - consensus of opinion; retire my original battery (I didn’t realise age was stamped on it).
So I changed the battery; got an MB VARTA AGM from local MB for the same as after-market one.
Fitted it, cleared the faults, reset the windows and normal service was resumed …….and all was good again.
Six months later - it’s happened again; large battery warning symbol (after 50miles trip), central locking, fuel gauge, indicators all stopped….
I put battery on charge - it went through its charging cycle (NOCO GENIUS10) in a matter of minutes and settled into MAINTENANCE MODE.
That suggested (to me anyway); that the battery wasn’t really flat - but I left it 24hrs, put it back in car - and everything back to normal.
Next day I tested the battery with a BATTERY TESTER (SOLAR BA7) and TBH, I couldn’t see anything wrong:
All best Ed
- Lo load voltage was 12.82V
- The TEST reading was 929 (CCA I guess that’s the units) - it gave a status of GOOD / GREEN.
- I took a reading at cranking load - voltage dropped to 9.69V.
- The Charging Voltage at 1,500RPM was 14.32V No Load.
- The constant At Load reading was between 14 and 14.2V.
All best Ed
