Neil Mackay
- Nov 17, 2011
- C32 AMG Estate
A per the title, if I was to supply the fluids and parts needed for a gearbox oil change including the torque convertor to my indi, what would I need?? I'm going to supply the engine oil as I can get the Mobil Merc spec oil for £30 for 5ltrs so for the 8ltrs needed I'd save £35+ on the indi supplying!
Plus would it be worth replacing the electro plate with all the electronic bits at the same time? (Don't have any iffy gear change issues more a preventative maintenance approach and does the C55 plate fit the C32)
Thanks in advance!
Thanks in advance!
