Hello everybody, I'm new on the forum and I hope somebody can help.
My w203 2005 200 cdi has been having some issues lately. It throws the check engine light and when scanned with the icarsoft device it shows the 3 codes attached as pictures. The issue is intermittent and mostly comes when the tank is over half full which leads me to believe the car is trying to do a dpf regen. If the codes are cleared the car drives normally and has full boost for the next hours. When the issue comes back the car goes into limp mode sometimes without throwing the EML, and sometimes the EML comes on but the car doesn't go in limp mode, this makes me think that I'm dealing with 2 different problems here. Can anybody point me in the right direction?
The car has already got the DPF sensor replaced but no luck. I also undid the hoses and made sure they weren't blocked, and also made sure the connecting points where the hoses mount to the exhaust weren't blocked and cleaned them but after driving for a bit the fault code came back. Also checked the live data of the dpf sensor while driving and with the revs below 2k it showed zero or -1. Above 2k it went up to 3 or 4. The values were checked with the icarsoft v2.0 and the unit is hPa in case somebody is interested. Any clues to what I should check next? I also tried gently blowing into the sensor while plugged in and the values were changing, which leads me to believe the sensor is fine.
Another interesting thing I noticed is that the ash content is at 0% load state of the filter is at 105% which leads me to belive that the car maybe has had the dpf removed from the previous owner. This could also be the reason why the sensor reads 0 as pressure difference since the 2 hoses connect before and after the dpf. Can anybody shed some light on this?
Edit Quote
Edit Quote
