W221 Headlights always on!
I had to remove the fuse box cover under the hood to check a fuse for the command display.
I have refitted as it was but I have noticed that when I start my car the headlight come and stay on! Changing the switch settings in the car makes no difference.
The day time running light settings work for the lower lights as it should via the menu on dash.
Can some one point me to where the sensor is for the lights? I believe it must be around the fuse area and I may have knocked it while removing the fuse cover?
Argggh
Argggh
