GDAWG10
Done. I had it front facing because I read it needed to be but I've turned it now.Before you do anything else rotate that bottle and unkink the pipe.
is that writing on the sloping sides of the regulator? what does the black lever on the top do? is it an on/off switch?
Greek Cypriot - UK bornAre you Greek?
Its not in any rush, can take an inordinate amount of time to purge thru
And you’re asking about GAS barbecues!!!
Gas all the way then.Yeah haha, to be honest I'm not interested in arguing with the rest of the Cypriots about charcoal barbecues LOL. We have an apartment with a big square balcony and a larger tiled roof garden/roof top space above it but it will be hassle to lug up bags of charcoal and then have to clean out the ashes every-time, this way I can start it up easily whenever I want and it's not as much mess, but that's if I can get it going
That regulator that you have purchased can be a buggar to push/clip on fully to the bottle. Unless it is fully on the gas won't flow, You said you could smell a bit of gas after wriggling the regulator so that may be the issue
Put the regulator on with the tap closed and make sure it is fully home (press very hard) then open the tap and the gas should flow
kc
It may be a good idea to take the bottle as well so the shop can show you how to connect it properlyYeah, I bought this one (the first picture) but I've seen the one below in a lot of pictures, not sure what the difference is but maybe the second one has a longer pin or different locking set up which will work better. I might go back and get this one later today to try it.
That's a good point actually as well. Not sure the shop will be happy with me walking in with a 10kg gas canister, most aren't that helpful here, but I could disconnect the hose from the regulator and then I will be able to feel if gas is flowing so I can see where the issue is. Gonna go and buy the different regulator later anyway because it's what I've seen in most pictures.It may be a good idea to take the bottle as well so the shop can show you how to connect it properly
You can then turn the tap on for a second to feel the gas coming out
Do not smoke while attempting this
Thanks for taking the time to look so carefully but that was when I had the hose to the side because I read the bottle should always be front facing but I turned the bottle a little bit and brought the hose round so the regulator could sit on the opening on the front but still no luck. Gonna try one more time in a minute to push down as hard as I can (not sure I can go any harder) and if it still doesn't work I'll get the different type of regulator.Looking at your pictures in post 17 the regulator seems to be sitting at an odd angle on the bottle, as if it's not properly seated. This would stop gas flowing without doubt. Try pushing down on it a bit harder.
if it is the type of regulator the you lift up the black ring to release it from the bottle, try lifting the black ring then push the regulator onto the bottle and release the ring. a very light squirt of wd40 on the locking mechanism but not the bit that goes into the bottle might help. I am guessing the reg is held on by ball bearings in grooves, if they are dry they can be akward to move
edit. from the pic of you holding the regulator there is quite a bit of the black "skirt" showing above the release ring but in the pic with the reg on the bottle there seems to be less "skirt" showing. it could just be the camera angle but i think that the pic with the most showing is also how much should show when its on the bottle correctly
Glad you finally have success.This was the comment that turned the lights on! Finally got it working. Bought the new type of regulator but still wasn't working, but basically I was pushing the regulator down from the top after locking it on, but you really need to wiggle it and push down on the black skirt and it drops down a touch more. View attachment 145221
Turned it off at the valve/regulator and will buy a fire extinguisher and check for leaks as well before it's next used. I assume it's all safe in the off position on the regulator/valve combo.
