Lowering w202 C230k
SamW
Kent
2000 W208 CLK320 Coupe Elegance
Shocks and springs
Just springs
Coilovers
Anything considered to sort the attitude & altitude out.
Please dm with whatcha got, where you are and how much.
:thumb:
A friend of mine had a set of these on a late 90's BMW 5 Series, raved about them when he bought them at how cheap they were but they failed pretty quickly, replaced and failed again what failed I am not sure but it ended up with him swapping back to the original BMW items.
A cheap way to lower a 202 is to replace the rubber shims (fitted on top of the springs) these are manufactured in varying thicknesses according to what model/spec the car is if you have the thicker ones then by replacing with the thinner ones you can lower it quite a lot up to 18mm , depending on what was fitted from the factory.
Also if you are running 18" AMG 210 E55 Wheels then be careful how much you lower the front as you "could" start fouling the front arches especially if you running 210 size tyres.
Don't like bumping but anyone got anything?
Been looking at these but seem too cheap to be any good, would prefer some better quality hand me downs really.
https://www.ebay.co.uk/itm/141762783116
I'm no experience of those and honestly I never will have either. Simply, they are cheap for a reason. If you are buying new stick with leading brands like H&R or Bilstein kits etc would be my advice. One more thing, I wouldn't fit coilovers on the front of a standard W202, again just my opinion.
Appreciate your help gents.
Im gonna swerve those Chinese nasty ones but out of interest, how come you wouldn't fit coilovers on the front?
It has bilstein shocks and I believe standard springs with pads removed. It's not high but I'm not happy with how it sits and think will benefit from a slight drop.
The car looks great.
The reason for me is simple. The inner wing top mount was never designed to support both shock and spring.
