OneForTheRoad
- Apr 20, 2015
- Location
- uk.
- 2019 Glc coupe 350d was 2017 e350 c207 .. +65 ford kuga 2.0 cdi zetec awd..
Maybe after another payout ??
Do this before you do anything else. It's not expensive and you will be dealing with a specialist who can talk you through it. My tyre guys are always more than happy to talk.I had a full wheel alignment done recently with a Hunter machine, after checking the original setup the operator clamped the steering wheel perfectly straight, he then made the necessary adjustments.
From then on the steering wheel is dead straight, as mention above, the wheel will not offset due to carrying passengers.
As also mentioned one missing bolt on a five stud hub will not be noticeable.
Replace the bolt and look up your nearest Hunter alignment centre and re align.
That’s what I thought but the master tech seemed legit. The final time I got it back, steering wheel was pretty straight with just me driving. When a passenger sat In the car, it would go off set. Same side as the missing wheel bolt. But on the same side (same axle) I can hear a light knock over bumps from what sound like the suspension, the same side the castor angle is out as well.. confused.com…
No chance the missing wheel bolt could be a suspect ?
