ccp
- May 24, 2006
- Location
- Houston, Texas
- A7 3.0 TDI quattro / Q7 3.0 TDI quattro
Yesterday my C Class was recovered to my local MB dealer because of a grinding/grating noise emanating from the front off-side. The reason for the noise was the lower spring cup being in contact with the wheel. The photos show one shot of the near side (with separation between the spring cup and the tyre)
and two shots of the off side where the spring cup is in contact with the tyre.
The ride height (gap between the top of the wheel arch and the tyre) seemed largely unaffected.
I was tempted to take the wheel off and try to fit the space saver to see if the smaller wheel would be clear of the spring cup, but thought better of it because I feared the spring might "release" completely as I took the wheel off + the car was parked on a slope that made jacking unpalatable.
From my inspection I guess that the spring cup has become detached from the shock absorber, but without taking the wheel off I couldn't really see. Assuming that this proves the case the car will need a new shock absorber.
So here's the question - should these be replaced in pairs or will it be ok to replace just the one?
The car is 8 years old and has done 105K miles.
