w211 E320CDI SUMP LEAK
boxer 01
w211 e320cdi sport g7 with paddleshift
Hi whilst carrying out oil service I noticed that oil sump is leaking. On closer inspection the seal seems to be some type of sealant I was wondering what type of sealant this is and whether it can be done by myself I would be grateful if any of the experienced members could provide a detailed procedure to carry out repair.
I have a roll of ptfe gasket material which is approximately 10mm round and on tightening will fill the seal gap perfectly but I am not sure how ptfe reacts with oil. I have only used on hot water/steam and it's superb (it's also very expensive.)
Regards
Boxer
Thanks for the advice, just what I was looking for. What size tube, is 70mg enough to do one sump repair.
Could also be your oil cooler leaking ££££
Make sure there isn't oil leaking down the passenger side of the engine/gearbox.
Above the sump all-round dry and the sump gasket I was told needed doing a couple of years back. So the sump will be resealed soon and thanks for everyone's input much appreciated.
Hi you don't happen to know the original mb part number for a 2007 e320cdi oil filter the engine number starts 642.
