E240estate
- Aug 19, 2014
- 2003 S211 E240 Estate; 2003 W638 Vito
Hi, odd problem with the windscreen washer.
Fluid full, jets clear.
When I turn on the ignition, washer works fine, ie I hold the button down and the spray is strong and continuous.
When I start the engine, a press of the button only gives about half a second of water and it switches off.
It will repeat this five times then refuses to work at all, until I stop and switch off and restart.
At that point it works fine again with the ignition on, then start engine then five short bursts then nothing.
Pretty certain it's an electronic issue with the pump switching itself off or controlled by the computer, and not a physical problem like leaking or lack of pressure.
Any help appreciated
